maitresyoda avatar image
maitresyoda asked
How can I share 3 x AC coupled Victron systems in a microgrid?
I have 3 installations in my home in AC coupling. The grid is here only when the SOC is under 50% controled by CCGX.
When i don't go to the Works in week end, the batteries are Full and the Labo are Full too and i need energy for my Home and sometimes the Soc is under 50 %, i don't want to take the Grid.
When i go to Works or Labo in the week, my Home is Full and i need energy for Works or Labo. I always disconnect from grid when the SOC is upper than 60%.
How can i share this Full batteries beetwen Home Works and Labo ?
How can i install and configure to make a MicroGrid ?
Where i can connect the 4kWc ?
Thanks
AC PV Coupling
Paul B avatar image
Paul B answered ·
All you can do is to connect all 4 inverters in Parallel and all the batteries as well. and solar
and make one micro grid system
It will all depend on how far they are away from each other.
if all 3 run off the same feed in line then put the micro grid there and feed all 3 sites from that connection.
