Paul B avatar image
Paul B asked
When using a CCGX Unit thats connected to the Internet is there a way to find the Main routers IP address
This is NOT a Victron issue in anyway. Just a general information request.
I am just trying to use the CCGX as a way to backdoor information for my office routers IP address.
as the CCGX unit connect at the Office and its alway's connected to the internet
When looking on the VRM under the Device List and then the gateway I can see the office CCGXs local IP address ie 192.168.1.67
However I am wanting to find out what the Office's - Main routers IP address is (assigned by the ISP)
Does anyone know if this is possible on the .
CCGX or venus units or the VRM to do this and if so how can it be achieved. remotely
Reason
The office Router has a dynamic IP assigned by the ISP ( its quite hard here to get a static IP Address)
and from time to time this IP address changes (as expected).
Sometimes I log into the office via Remote Desktop from HOME and if the ISP has reset the IP address, I can no longer log in via remote Desktop, until I find out what the new IP address is,
Hoping that I can find this out the new IP address via the CCGX/Venus Unit somehow
Currently I Have to call the office and ask one of the staff to run whats my IP address and advise me the new IP address number , but if its a weekend or late at night its a drive to the office.
Anyone got a Idea here
THANKS
PS Sorry if this is off topic but if its possible others may also be able to use this as a tool
CCGX Color Control
treadlite avatar image
treadlite answered ·
I have looked all over in the UI, and within VRM, I cannot find anything....but if you are a bit tech savvy, you can do this:
From what I am reading you can ssh into a non-rpi CCGX?
If that is so, you could easily setup a cron job to do something that would update the IP in some outside location.
here is an example of a cron job you could run and put it in /etc/cron.hourly or /etc/cron.daily
import urllib
import re
import smtplib
import sys
# Setup our login credentials
from_address = ''
to_address = ''
subject = 'CCGX IP'
username = ''
password = ''
# Setup where we will get our IP address
url = 'http://checkip.dyndns.org'
#print ("Our chosen IP address service is ", url)
# Open up the url, then read the contents, and take away our IP address
request = urllib.urlopen(url).read().decode('utf-8')
# We extract the IP address only
ourIP = re.findall("\d{1,3}\.\d{1,3}\.\d{1,3}\.\d{1,3}", request)
ourIP = ourIP[0]
print ("Our IP address is: " + ourIP)
def send_email(ourIP):
# Body of the email
body_text = ourIP + ' is our PlayPi IP address'
msg = '\r\n'.join(['To: %s' % to_address, 'From: %s' % from_address, 'Subject: %s' % subject, '', body_text])
# Actually send the email!
server = smtplib.SMTP('smtp.gmail.com:587')
server.starttls() # Our security for transmission of credentials
server.login(username,password)
server.sendmail(from_address, to_address, msg)
server.quit()
print ("Our email has been sent!")
# Open up previous IP address (last_ip.txt) and extract contents
with open('/data/home/root/last_ip.txt', 'rt') as last_ip:
last_ip = last_ip.read() # Read the text file
# Check to see if our IP address has really changed
if last_ip == ourIP:
print("Our IP address has not changed.")
# ucomment out this line next if you want to send email regaurdless
# send_email(ourIP)
else:
print ("We have a new IP address.")
with open('/data/home/root/last_ip.txt', 'wt') as last_ip:
last_ip.write(ourIP)
print ("We have written the new IP address to the text file.")
send_email(ourIP)
JohnC avatar image
JohnC answered ·
Hi Paul. No, I don't believe that's possible from the Victron side, neither via GX nor VRM.
Victron at the VRM end would know of course, but that won't be publicly available.
Maybe your office needs some sort of Dynamic DNS setup?
