John Rushworth avatar image
John Rushworth asked
CCGX - How to Customize the logo on the Boat & Motorhome page
  1. This is both a question and an answer, as I discovered the answer searching/reading the Victron blog - and I thought others here might find it useful.
As shown in the image above, you can now upload your own logo onto the Boat & Motorhome page. Great for motorhome builders, boat builders, and other OEMs that want to add their own touch to the system.
How to change the logo
Using this address as a template: http://[ip-here]/logo.php (inserting your device’s IP address between the square brackets) type that address into a connected browser – the IP address can be found by going to Settings > Ethernet or Wifi. From there you will see the screen above. Choose an image file from your computer. That’s it! ….but don’t forget to re-boot the GX device.
CCGX Color Control
Gerardo avatar image
Gerardo answered ·
Hi John.
I am trying to change the logo of my CCGX. I connected it via Ethernet and got access to the "change logo" option. However, after rebooting my device, I cannot see any change.
In the browser says the logo was changed successfully but I cannot see it displayed in the CCGX.
Do you have any advice I can test?
Thanks
John Rushworth avatar image John Rushworth ♦♦ commented ·
Hi.
So as you say, you have got the logo per the manual:
https://www.victronenergy.com/live/ccgx:start#customize_the_logo_on_the_boat_motorhome_page
Now and assuming you have the latest firmware as of this reply:
https://www.victronenergy.com/blog/2019/12/20/venus-os-v2-41-fixing-byd-communications-and-more/
I don’t have a CCGX handy but now I believe you need to enable boat/motorhome display in settings. I don’t think you had to previously. Find that and enable and reboot if you haven’t already.
