ddventer avatar image
ddventer asked
Inverter Temperature Sense Error
img-3327.jpegEverytime I turn on my Inverter I get this error and the Cerbo starts beeping. Once I read the message, the beeping stops. Everything is working, can someone help me figure this out?
Temperature Sensor
dc-marine avatar image
dc-marine answered ·
First thing I would check is making sure your temperature probe is connected with the right polarity to the right ports. You didn’t mention which inverter you have nor posted a picture of the connections, but I know it’s easy to connect to the wrong port or reverse polarity if not paying attention during assembly. If you have more than one inverter/charger then the probe should be connected to the master unit only.
Victron temperature sensor disambiguation table - which product supports which sensor
