xrtx avatar image
xrtx asked
VRM app has stopped showing solar inverter input
Running a Venus GX. It's connected to a meter that provides data on the inverter generation. It has worked fine for years, but then the inverter generation only appeared intermittently, eventually never appearing. For a while, if I rebooted the GX, by unplugging its power, and 10 seconds later re-applying the power, the inverter would reappear within the VRM app. After a while, when it repearedly kept 'losing' the inverter, even the re-boot doesn't work. The feed from the meter appears to be working - well, the plug usually flashes as normal.
I'm thinking there is either an issue with the software on the GX, or with the hardware itself. I believe this because I had 'success' for a while, making the inverter reappear by the reboot method. This suggests that the meter is transmitting, that the cable is okay and the GX is receiving, and logging if only for a short while.
Does anyoine have any straightforward suggestions as to how I can determine where the issue lies, and maybe correct it?
Venus GX - VGX
Probably aso best to mention what meter it is?
If it goes missing from the GX device list though, it wont transmit to the VRM
xrtx avatar image xrtx Alexandra ♦ commented ·
xrtx answered · 2 secs ago
It's a Carlo Givazzi 3 phase meter from Victron itself. As I mentioned, the Venus GX has worked with it previously (for years) without issue and recently after a number of reboots. Something has now happened and it has stopped registering the meter's presence. It could be a software update, I presume, or a hardware failure in the GX, the cable and plugs, or the meter.
I am pretty certain this is caused by a software update. The Victron USB/RS485 plug is flashing both green and red which suggests it is both transmitting and reading from the meter, but nothing shows up on the VRM app.
jetlag avatar image jetlag xrtx commented ·
You can check the meter with the Carlo Gavazzi configuration software UCS. If this is showing the values, then you at least know that the meter and the cable + the RS485 to USB adapter is working. Then it can only be the GX device, either HW or SW.
