Robin avatar image
Robin asked
cerbo to bms custom cable
Hi, ime looking at Basen Green lifepo4 300ah BR-OW-LV battery. To connect the BMS CAN port to the cerbo gx can port .They provide RJ45 cable. Battery end CAN-H pin4 . CAN-L pin 5. GND pin 7 . I think it has bare wires the other end. Should they connect cerbo end . GND pin 3 CAN-L pin 8. CAN-H pin 7. Does This have to be a terminator plug with 1200ohm resistor or not? Ifso is this the plug that is provided withe cerbo?
cerbo gx
