After update to 1.42 on smartsolar, victronconnect can't save the settings from smartsolar to file.
I'm running victronconnect on android version 9.
Is there other than me Who has this problem?
Is there a solution?
I also have a similar problem when using Victron connect V5.31 on windows 10 and the 75/10 has V1.50 installed.
However, save settings to file works when Victron connect is running on android.
But.....
Am unable to load any saved file into a device using Victron connect V5.31 on windows 10 without seeing an error message.
Automatic [mandatory] updates are a nuisance.....
10 People are following this question.
