What's the max. size cable that will fit into Lynx Power In.
Thanks Tony
Hi @tonyat59,
From the bus bar, the maximum external wire size diameter (including insulation) is 22 mm, without some modification.
It would be possible to run larger wires from the part of the bus bar that protrudes from the plastic housing. Though these would not be part of the fused connections.
The lug is an M8.
10 People are following this question.
