samsamsamsamsam avatar image
samsamsamsamsam asked
More memory for /dev/root
Hello
I have a Cerbo GX with 8GB memory instead of 4GB.
I would like to have more memory for /dev/root.
With the script
/opt/victronenergy/swupdate-scripts/resize2fs.sh
I have tried to free up more memory.
However, only 1.3 GB is enabled for /dev/root.
root@einstein:~# fdisk -l
Disk /dev/mmcblk1: 7.29 GiB, 7818182656 bytes, 15269888 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x564e5553
Device Boot Start End Sectors Size Id Type
/dev/mmcblk1p1 * 2048 18431 16384 8M c W95 FAT32 (LBA)
/dev/mmcblk1p2 18432 2639871 2621440 1.3G 83 Linux
/dev/mmcblk1p3 2639872 5261311 2621440 1.3G 83 Linux
/dev/mmcblk1p4 5261312 15269887 10008576 4.8G 5 Extended
/dev/mmcblk1p5 5263360 15269887 10006528 4.8G 83 Linux
root@einstein:~# df
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/root 1202464 1087480 39112 97% /
devtmpfs 465376 4 465372 0% /dev
tmpfs 515040 848 514192 0% /run
tmpfs 515040 284 514756 0% /var/volatile
/dev/mmcblk1p5 4859040 138628 4453868 3% /data
tmpfs 515040 848 514192 0% /service
overlay 515040 284 514756 0% /var/lib
Thank you
Sam
cerbo gxVenus OSroot
