Hi, I've installed an Orion XS with the D+ signal plugged on H pin, but I'm not sure if the Engine Shutdown Detection must be turned off. Reading the Manual, think it should be, but I'm still not sure.
Thank you for your reply.
I’m assuming you are talking about D+ on a Sprinter Van. I have my XS set up the same way, and the Engine Shutdown detection needs to be OFF.
Hi David, thank you for your reply. D+ on Citroen Jumper van 2021.
Actually reading back the manual, I think the set up falls into the Remote On/Off Connections case, where "the engine shutdown detection must be switched off".
By the way, in connecting D+ signal to pin H, I removed the bridge between L and H pins. Did you? Greeting from Italy
Victron DC to DC Converters Product Range
__________
__________
41 People are following this question.
