My Cerbo-S-GX just shuts off. unplug and it boots up and stays up sometimes days and sometimes just hours. How do I find out what is going on. It is on the latest update.
TIA Ned
TIA Ned
Doesn't appear to be hot. It has a 12 gauge wire direct to 2 lithium battle born 100ah 12.8v batteries in parallel. I have 2 MPPT controllers and shunt that report full charge and have no issues. If I turn off the battery switch and turn it back on the Cerbo boots right up.
So an update, Cerbo has been up consistently. I had run my HDMI/USB extensions close to my hot water tank in the RV. So when I powered on the HW Heater the Cerbo would shut down. I have rerun the extensions and will see what happens when the HW heater is turned on now.
91 People are following this question.
