oliver-1 avatar image
oliver-1 asked
REC BMS with Cerbo GX DVCC and Quattro, limited charge current
System was running well, but due to some other error research I had to reduce MAXC in REC BMS to 20A.
Now I have reset back to 250A but for some reason Quattro is not spotting out more than 50A DC current.
Power off/on REC BMS - no change
Current limitation in DVCC setting is turned off
Setting of 250A limit is visible correctly in Cerbo.
Any idea what setting is still limiting the DC current?
cerbo gx
