cc5084 avatar image
cc5084 asked
Cerbo GX Communication
I'm going to connect a bmv-712 smart, MPPT 100/30, muliplus 3000W inverter, and Orion XS to a cerbo GX. I am going to configure each component to be compatible with a lithium battery. Is there any additional programming or parameter changes that I will need to do with the cerbo GX in order for it to communicate with everything properly? Or, does it simple automatically communicate information when a component is plugged in?
cerbo gxMPPT SmartSolar
Alexandra avatar image
Alexandra answered ·
@cc5084
Usually it is straight communication plug and play. (If you get the ports right - watch the rj45 ones )
For your chosen components it will be anyway.
cc5084 avatar image cc5084 commented ·
That is what I figured but I just wanted to get a second opinion to be sure.
To follow up on that question, do you know what all is being communicated exactly? I know roughly that it is basically the state of charge of the battery, and the current going in/out for charging/discharging. Is there anything more in depth to it or is it pretty simple like that.
