Hello
I can‘t solve this problem on my Cerbo GX. I have it over VRM.
Can anyone help me please?
Have you enabled node red in the large image?
Tried a reboot?
Thanks for the answer.
Venus large version enabled, disabled, enabled, disabled, enabledNew firmware, old firmware, new firmware
reboot, reboot, reboot
Protected mode for nodered, fullmode, disabled, enabled
No success.
I don't know what to do.
There is a process for removing it (stop, delete folder, change back to small image, then revert to large image again).
That may help.
Else, just follow the Cerbo reset process, this should now be in the docs as well.
Maybe, also check the GX hasn't run out of space.
And wich folder I have to delete?
Iirc the folder is quite obvious, but the process has been discussed before so should be easy enough to find by a quick search. If you don't come right I will find the link for you.
89 People are following this question.
