guido77 avatar image
guido77 asked
Update firmware multiplus
I have a Multiplus 12/3000/120-16. It is is connected to a cerbo using ve.bus. firmware version is 143. I bought it second hand. It works well..
The cerbo is at firmware level 3.31. I have a connection in the vrm portal. When I go to devices I can go to firmware update. Vrm tells me that a firmware version is available. Product Id 1909, Id /dev/ttys4, serial number unknown, installed v143, latest v209 and updateble is telling me 'not updatable (1342). Does anyone know how to solve this? I think I should buy a MK3 usb adapter to update it with my laptop. Am I correct or does anyone have another quicker or cheaper solution?
Ve.bus version is 1909143
The reason I would like to update the machine is because I think the firmware is much older than the firmware from the other devices. The others are a cerbo, mppt, Lynx distributor, smartshunt, Orion.
I live in The Netherlands on Marken. I can see Almere from my house :-)
multiplus ve.bus
