dazza555 avatar image
dazza555 asked
Caravan with buck boost DC Dc
Hi all,
Our caravan is set up with Victron Lithium set up and has a Buck-boost dc-dc converter. The problem is that it doesn't charge when van is stationary and tow vehicle is running.
Can this be programmed to work with no vibration (or do I need to change to a different unit).
The second Q I have is does it shut down if the tow vehicle is putting out around 14.5 volts if so can it be programmed to accept tow vehicle voltage or do I need to reduce voltage from tow vehicle.
Thanks in advance as the caravan manufacturer has no idea even though they fitted the setup.
Darren
battery chargingcharge controller compatibility
199-big avatar image
199-big answered ·
Hi Darren,
for you first question: you can change the settings (50) that the converter starts with pin 1 (purple wire) or checking the input voltage.
2nd Question: you can setup the output voltage (setting 20) to the voltage you want - for victron lifepo4 choose 14.2V
Use the victron tool TSConfig to change parameters.
Best regards
Hartwig
dazza555 avatar image dazza555 commented ·
Thanks Hartwig, so if my vehicle is putting out 14.5 volts that will be to much and I need to reduce that to under 14,2V
Thanks Hartwig,
Found the problem thanks, changed 50 to purple wire as suggested and although my truck was showing 14.4 V on the display when the converter started pulling was dropping to mid 10's, so lowered minimum input to 10 and works. Thanks again for your quick response.
Darren
