ksmith31 avatar image
ksmith31 asked
Multiplus II HEAVY humm when charger enabled
I have three 48/5000/70 Multiplus II units configured in parallel mode for a on-grid house system.
If I enable ESS, or if I enable the inbuilt Charger, it emits a very heavy HUMM noise. The lights in the house dim and pulse to the noise. I have read multiple posts about noises and I think some noise is normal, but this noise shakes the house. It happens regardless of load.
Any ideas on how to debug or resolve?
Multiplus-IIESScharger
Duivert NL avatar image
Duivert NL answered ·
Sounds like there is something wrong with the wiring, did you follow all the steps in the manual:
https://www.victronenergy.com/live/ve.bus:manual_parallel_and_three_phase_systems
parallel systems are complex and good wiring (equal lenghts and right cross section) is mandatory to get it work right
ksmith31 answered ·
Thanks. I believe its all perfectly matched with same torque values on all posts etc.
Interestingly it does not occur when I use the Charge Current Control assistant.
