pfuhu avatar image
pfuhu asked
Energy meter on AC PV inverter necessary for dynamic ESS?
I currently have a Multiplus II GX with a battery. I also have a PV inverter, but this is AC-connected to the AC-input of the Multiplus (older inverter). No PV directly connected to the Multiplus.
I also have a grid meter.
I wanted to start using the Dynamic ESS, but I notice this does not work well in my current setup, since the GX has no idea of the solar power that is generated (it doesn't even know I have PV and also impossible to make predictions of solar output).
Is it correct that if I install an energy meter on the AC PV inverter, the GX can now register the solar output (and make predictions) so the Dynamic ESS will work properly?
Thanks
Multiplus-IIEnergy Meterdynamic ess
Duivert NL avatar image
Duivert NL answered ·
Short answer: yes :)
pfuhu avatar image
pfuhu answered ·
And so I can assume that in that case it will also correctly calculate the correct AC consumption (taking the PV power in count) since it then knows all values to calculate this?
Yes, it will, its never 100% accurate but the more info the better result
