albedo avatar image
albedo asked
BlueSloar PWM negative pole connection
I have BlueSolar PWM-LCD&USB 12/24V-20A installed in my car. Since I have line losses (socket far from the regulator), I wanted to ask if the regulator will still work the same if I connect the negative terminals of the load and the battery.
Thank you
BlueSolar PWM
