mindaugas avatar image
mindaugas asked
Node Red on Cerbo stops many times a day
I have a programed logic on Node-red adjusting grid feed in depending on SOC, solar etc.
The prevoius version worked fine for quite long time.
What I have done recently:
Upgraded Cerbo to latest version
Improve Node-Red flow adding some extra checks
Since then, not sure what was reason I have found that my logic stop working. After more investigation I found that restart of Node-Red or restart of Cerbo fix all.
I also found that after this happen I can not access neither Dasboard or Node -Red
Node-RED unreachable
Normally Node-RED can be found on this location. It either is starting and will show after a refresh, or it is not enabled in menu. More information on Node-RED on Venus can be found here.
All the rest except Node-Red works on Cerbo after crash
Full reinstall of node red using venus-data-20-node-red-reset.tgz didnt helped.
Memmory status
Deletion of previuos versions files did not made any impact
cerbo gxNode-RED
matt1309 avatar image
matt1309 answered ·
Hi @Mindaugas
Are you able to share the changes you made in node red recently. Maybe someone can spot an issue that's causing the crash.
It may also be worth checking the node red logs. /var/log/node-red-venus
Might give you some clues as to what's causing it.
mindaugas avatar image mindaugas commented ·
It works for aprox 6-8 hours and then stops any time. Looks like duration from restart matters not some logic on node red. Same logic used on another cerbo by my friend who was who helped me to write it and it works without any stop.
I havent tried to disable that logic. I will try during weekend just to see if this helps to find a issue
Thanks I will check logs
Fideri avatar image
Fideri answered ·
@Mindaugas
I was having unexplained issues with Node Red but starting it in "safe mode" helped. I expected it to revert to normal mode automatically on deploying my nodes. It remained in "safe mode" even after restarting my Cerbo but I could still use any function I needed. So I left it there. It's now more than 2 wks and it's running flawlessly.
F.
Thanks
Let me try safe mode
I am about to reinstall Cerbo
Mindaugas
I got this warning when started in safe mode. But after Deploy all works, let me see if this will help
Fideri avatar image
Fideri answered ·
The warning is normal.
mindaugas answered ·
after resize2fs.sh - got extra space
Anders avatar image
Anders answered ·
It does look like you have messed up your root - I experienced something similar some weeks ago - a factory rest according to Victron procedure solved this, but I also experience that Node-red lock up frequently during the day. A Cerbo GX restart solves it but is annoying.
It does not look like Node-Red actually stops running - It could be that it's only the Dashbord and the access to Node Red thats stops working -
I have a rather heavy Node red installation consuming 50% of CPU.
50% cpu means that one of your two cpus is totally maxed out.
-> not good for single threaded applications, like I think Node-RED is.
Dirk-Jan Faber (Victron Energy) avatar image
Dirk-Jan Faber (Victron Energy) answered ·
Node red only writes to the /data partition, so the disk space can't be causing it.
If Node-RED crashes, it usually writes a log line into /var/log/node-red-venus/current.
You can check that file by typing `cat /var/log/node-red-venus/current` or `tail -f /var/log/node-red-venus/current` (and ctrl-c ing when done).
