vuca-maven avatar image
vuca-maven asked
Using MK3 instead of MK2 to upgrade firmware?
Can an MK3-USB cable be used (instead of MK2-USB) to upgrade the older firmware (e.g. on the MultiPlus) which requires the use of VE.FLash? I assume it would have to be done from the Windows machine, since that's the only OS that VE.Flash works on - correct?
firmware update
Alexandra avatar image
Alexandra answered ·
vuca-maven avatar image vuca-maven commented ·
Thanks Alexandra. UPDATED - I am all set. Thanks!
alexben avatar image
alexben answered ·
On my Multiplus was a sticker on the chip that is in a socket so it can be replaced. It had the 7 digits and then “.VFD” after it. On my case it was supplied with Version 413 it seems. I got it with V498. Updated to 510, but still bricked. img-9639.jpeg
And what happened after it bricked? Were you able to fix it?
