image6255 avatar image
image6255 asked
Victron, Pylontech, legacy solar and ESS
Just installed a MultiPlus II GX with two Pylontech US5000 batteries and enabled ESS.
My installation has nothing on AC outs 1/2 and there is a Victron CT clamp on the grid connection which is connected to the Multiplus.
Also I have a legacy PV system which is on the AC IN side.
Essentially, I want my Victron to charge the batteries when there is a grid export and discharge into AC IN when there is a grid import over some threshold.
Could you give me a hint how should I set the system up please?
Should the ESS / Grid Metering option be set to "Inverter/Charger" or "External Meter"?
Thank you.
ess settings
duivert avatar image
duivert answered ·
You should set it on external meter, grid meter
Accuracy and speed is not that high
If you want better performance, use a ET112 on grid connection and an ET112 on the PV inverter
Also you will have to set a grid setpoint and maybe use scheduled charging to get what you want
You can read this for more unserstanding of how it works and set up:
https://www.victronenergy.com/media/pg/Energy_Storage_System/en/index-en.html
image6255 answered ·
Unfortunately, the linked manual does not mention CT clamps at all.
Although, from what I can see, if I set Grid Metering to "Inverter/Charger", everything works just as I want.
Yes, there seem to be some discrepancies between measurements from Victron clamp and other clamps I have, but that doesn't seem to be extremely important.
I'm considering adding an ET112 into my system but I'm literally out of slots in my fuse box. Fortunately, I have two spare twisted couples which should be enough for RS485 connection with my inverter, but I'm out of slots :)
