daza avatar image
daza asked
Enable ESS
Hi firstly not sure if ESS can be enabled without battieries is there a way to set it up for Pylontech US5000 batteries I have the MK3 USB cable for the Multiplus2 which will stay off after it’s been configured. The Multiplus2 seems to think it has a battery connected by defult and switches between low battery and absorption should I enable battery monitoring on the multiplus as I thought the GX was doing all the calculations anyone able to offer a setup for ESS, AC PV on critical load side of Victron?
ess settings
nickdb avatar image
nickdb answered ·
Do not run an inverter without batteries.
It is not designed nor supported.
I have lost count how many time this has been asked and answered here.
Before you ruin expensive gear, wait.
daza avatar image daza commented ·
Ok so needs battery to see ESS then thanks @nickdb
ejrossouw avatar image
ejrossouw answered ·
If you search the Victron website, there are comprehensive material, which you probably should have familiarised yourself with prior to hooking things up. https://www.victronenergy.com/media/pg/Energy_Storage_System/en/index-en.html
@ejrossouw everything is wired up, bar batteries as I’ve not got them yet. Two ET112’s PV and Grid working with Cerbo GX. I’ll look through it but all the things I’m seeing even Victrons video says it can be done from the GX
