schwuppe avatar image
schwuppe asked
node red - ess control values overwritten
Hello, I'm using version 3 of the venus large software with Node Red.
I want to manually set the battery not to discharce. Therefore I configured a output node
ESS Control - Disable feed-in
This works about 2 seconds, then the regulator discharges the battery again. Looks like another service is taking over control or do I need really to permanently send the trigger?
thanks a lot
ESSNode-REDess settings
wilm avatar image
wilm answered ·
Schwuppe,
use the "settings-control"-node.
Settings: "venus settings", measurement: "ESS BatteryLife state".l
Either take "7:sustain" to keep the battery level or as in VRM "9 Keep batteries charged"
HTH,
Wilm
sot avatar image
sot answered ·
"Disable Feed In" prevents feeding power back to the grid. That's not going to prevent battery drain.
schwuppe avatar image schwuppe commented ·
ok understood; what I saw was one phase was going from minus value to zero and 2s later back to a minus value where the sum of all phases was positive;
Node red triggered an initialization
