drokklir avatar image
drokklir asked
Including 12V Battery/Alternatior into 48V Solar system on RV
Good Morning!
I am planning a RV with 3x 360W solar panels, 2+ Pylontech US2000C Batteries, option to cennect with a grid to load the batteries and a (backup) option to load the batteries via the cars 12V Battery/Alternator (and optionally the other way around).
My current plan is as follows (fuses for 220V and 12V devices not included):
My first plan was to connect to the 12V Car battery with a BMS and an smart Orion TR. However there is no 48V SMART Orion-Tr.
Would a (non-smart) Orion-Tr (fixed to a good charging voltage) combined with a BMV-712 Smart (to activate/deactivate the charing) work for the 48V to 12V charging work?
I also found some people using a MPPT charge controller to get the 48 to 12V done, but this seems to be advised against.
My current workaround for charging the US2000Cs with the alternator/12V battery would be plugging a car inverter in and going via the Multiplus (something like this).
Is there a better way to do this?
As I am quite new here: Did I miss anything important with this setup?
For the MPPT, I d probably go for the BlueSolar 150/45, as the 3 Panels will serve 34,8A and this seems a little bit too low a margin of error for me. And the BlueSolar, bacause I will be able to access all data via the Cerbo GX anyways. Is this correct?
Best Regards,
MPPT Controllers48v battery48volt charging
MPPT Product Page
MPPT Error codes
