svgalatea avatar image
svgalatea asked
Color Control GX: Can't adjust brightness or make display sleep
Almost done installing my new system with a 12V Quattro, a BMV and CCGX. When I go into the settings for the CCGX and adjust the brightness slider, it doesn't actually adjust the brightness. And the display will not go to sleep, regardless of how long I set the timer for. What are some things I should try to remedy this? Thanks!
CCGX Color Control
5 comments
Murray van Graan avatar image Murray van Graan commented ·
Which firmware are you running? And did you do a reboot after the changes?
svgalatea avatar image svgalatea Murray van Graan commented ·
I am running v2.23. I did do a reboot and that did not resolve the issue.
Guy Stewart (Victron Community Manager) avatar image Guy Stewart (Victron Community Manager) ♦♦ svgalatea commented ·
The current firmware runs a test to validate the ability of the flash memory to store the settings. Please update to the latest GX firmware to see if this is the issue.
svgalatea avatar image svgalatea Guy Stewart (Victron Community Manager) ♦♦ commented ·
I updated the firmware and rebooted and that still did not resolve the issue. I think that the bus is not terminated inside the Quattro, based on the extra RJ45 terminator I have lying about. Could that cause this issue?
The included terminator is for the VEcan/CANbus connection, it is not needed for the VE.Bus connection between the CCGX and the Multi.
It may have a fault.
Please contact your Victron Dealer - https://professional.victronenergy.com/support/
