habie avatar image
habie asked
Dynamic ESS idle consumption
I recently set up a ESS system with 3x MultiPlus 48/3000/35-16. When the Dynamic ESS put's the inverters in 'idle' the keep discharging the battery with a significant standby consumption of about 200W. I want to see if I can reduce because it introduces significant losses.
I read about the AES search mode. However following the youtube tutorial I can't manage to open the downloade VE bus configuration file.
VE configure tells me I should open de .rvsc file in VE bus system configurator. And there I can't make any AES settings.
Any suggestion how to fix this?
dynamic essaes
Jeroen Peters avatar image
Jeroen Peters answered ·
I see very similar behaviour and have not found the fix unfortunately. Hopefully someone can find a solution to this idle draw and associated losses.
zonnigbreda avatar image
zonnigbreda answered ·
I am dissapointed in the high standby current drawn as well.
My current workaround is to set the battery in external control mode.
It seems to use less power in that mode.
I intend to make a nodered flow for this: If the battery is not actively buying or selling put the device in external control. Note: When you put it in that mode it complains abount the wrong ESS setting. What I don't know yet if that is affecting the creation of proper ESS buy/sell plan
