Preben Hansen avatar image
basic settings vitronconnect
I am brand new in terms of victron charge controller. Also here I never get used lifepo4 batteries but only gel.
There's so much new thermonology that I don't quite understand, and I'm not very good at technical English.
I bought a smart isolate 100/30. a Victron Energy Smart Battery Sense and 4 pcs 190 ah lifepo4 cells, and am very unsure how to set this in victron connect.
the specifications of the batteries are:
Product Name: Lithium iron phosphate cell
Shell Material : Aluminum
Rated capacity: 190Ah
Minimum capacity: 190Ah
Internal impedance: 0.1 ~ 0.3mΩ
Nominal voltage: 3.2V
Dimensions (L * W * H): 174 * 54 * 207mm
Weight: 4.0 ± 0.10kg
Recommend Constant Current: 190A (1C)
End-of-Discharge Voltage: 2.5V
Recommend Constant Current: 95A (0.5C)
Charge Voltage: 3.65V
Maximum Pulse Discharging Current : 528A
Max Continuous Discharge Current: 190A (1C)
Cycle life (80% DOD): 4000 cycles
Charging Temperature : -5 ~ 60 ° C
Discharging Temperature : -30 ~ 60 ° C
Is there someone who can guide me, this way down to the beginning stage so that I can make this work in my caravan
MPPT - Solar Charge ControllerVictronConnect
Do you have any cell balancers, or BMS to suit the cells?
Not yet, but it will arive in a few days
klim8skeptic avatar image
Hi PH,
You will find that people are not going to recommend any charging details, other than what your battery manufacturer recommends (details ???) or Victron pre-sets (very safe starting point).
Recommendations.
Have a good multimeter on hand. If you don't have one buy a DC clampmeter for a few dollars more.
Return the Smart battery sense, and buy a BMV712. The 712 is recommended for Li batteries, will network with the Smartsolar 100/30 to provide voltage compensation, and batt temp details. You cant get any sense of the batteries state of charge from voltage alone.
Fully charge each cell individually before bolting them into a battery. Hobby chargers (or bench power supply) are good for this. Monitor this closely.
Strap or bolt your cells tightly. Swollen cells are fubar.
TBC.
Share
