scottz avatar image
scottz asked
Temperature sensor with BMV712/shunt and Quatro II
I have a BMV712/shunt with a temperature sensor. I am in process of installing a Quatro II which came with it's own temperature sensor. Should I install both temperature sensors? If so, should I put both of them on the same battery terminal? My current sensor is connected to a battery positive termainal.
Temperature Sensor
scottz avatar image
scottz answered ·
I remembered that the BMV sensor attached to the positive battery terminal because it powers the shunt. The Quattro sensor attaches to the negative battery terminal. Question remains; should I install both?
Victron temperature sensor disambiguation table - which product supports which sensor
