Is there anywhere you can even pay to speak to a victron tech? I think 10 minutes with someone who really knows would negate hours of trying answer a simple question. Apologizes a bit frustrated after spending so much on victron gear. I have 8 solar panels on my catamaran and 8 mppt controllers. Yes these were purchased/installed from a Victron dealer and they are clueless. So now Iโm searching forums to see if it can be done, any advice greatly appreciated. Master volt does this on all of friends boats so I have to assume victron does as well. Four mppt 100/30 w Bluetooth and four mppt 150/30 with Bluetooth.
The GX display is about 15-20meters away from the 8 mppt controllers and there is a Quattro 5kw inverter half way between the two. Do I need 8 ve.direct to usb cables connected to a powered usd hub and then a 20m usd extension cable all the way back to the GX display? Can this be done in a simpler less complex way? Why have Bluetooth?
An second less important issue is I can see each individual controller but if I add up the output watts on each individual controller this total is about 40% less than what shows going into the battery.
Any direction is much appreciated Iโm ready to throw this stuff overboard :)
