since i updated to 3.30 few days ago there´s no more real time access.
No Firmware Updates possible nor Remote VEConfig (1392).
Updating the Venus to 3.31 fixes the Realtime but not the rest.
Regards
Regards
Same here, updated to 3.30. Constant error messages of Realtime update disabled due to device overload.
Forced to update to 3.31 using SD card as online update (local or VRM) was impossible.
Now 3.31, realtime is stable but further updates to let's say beta 3.40~10 is impossible.
Is your system modified? Custom software, node red etc?
Not even a cable is changed.
Just the firmware. Still 3.31.
Realtime gone, 1392 keeps showing when device list/firmware update
Then after another hour of intense trying to get all 154 settings back to normal it failed again.
Who pays for all this extra work?
So asking if any software changes have been made, for example, are there node red flows running, any of the custom scripts like serial battery loaded.
The suggestion to reset is because it eliminates any of these and provides a base working system and if that still has issues then we know there is a problem, more often than not, it comes down to software customisation, else there would be many complaints, not a couple.
Yes, it is inconvenient, but a GX doesn't have 154 settings, not a conventional one anyway. This helps troubleshoot the issue better.
I have asked if someone can take a look.
Ever really programmed a Venus?
Loads of settings indeed.......
It's many.
Not erasing everything for a MAYBE.
Been there, in 95% of the cases it was just for the extra hassle.
Bonjour,
Passer le système en IP fixe peut aider ... j'ai résolu le problème de cette manière sur deux systèmes mais pas sur que ca marche à chaque fois ...
Good morning,
Switching the system to fixed IP can help... I solved the problem this way on two systems but not sure that it works each time...
Victron Venus OS Open Source intro page
Venus OS GitHub (please do not post to this)
74 People are following this question.
