hannu avatar image
hannu asked
AC coupled fronius Distance restraint?
Good day
just a question is there a restraint in the distance between the fronius and output of a victron inverter? Meaning is there a maximum allowed distance that the machines can be apart? reason for asking is i have an existing fronius connected to a Sub DB and would like to install a victron and battery system at mains incoming which is 100M away
Any advice would be appreciated both systems will be connected to the same network
AC PV CouplingFronius
Duivert NL avatar image
Duivert NL answered ·
i dont think its a problem, if they can communicate it should be fine
maa avatar image
maa answered ·
Salut,
notre seule contrainte sera de respecter le jour sous-réseau ce qui signifie que vous ne pouvez pas faire de route (niveau 2 couche OSI), seul de commutation (niveau 3).
Bonne installation
Pour la mémoire
Your only constraint will be to respect the subnetwork day which means that you cannot do a route (level 2 OSI layer), only switching (level 3).
Good installation
For memory
