In VRM I see this:
The battery IS charging, but the block below says "Discharging".
It seems that this label is never updated. Whether the battery is charging or discharging, it always says discharging.
Is this a (known) bug in VRM?
Mike
In VRM I see this:
Mike
It’s discharging because it’s actually discharging, that’s the inverter tab , it’s carrying loads so it’s discharging , above u can see charging , so while it’s charging and at the same time carrying load, discharge shows , so u can compare the rate of charge vs discharge .
Def not a bug, I use it to keep tabs of discharge current and charge current , which totals the entire current into the system from all charging sources
That seems quite incorrect. Charge and discharge terms only apply to batteries, not inverters, and this is located under the SOC. There have been previous errors in reporting battery state, the only question is if this is being updated in realtime. I suspect not.
From the MultiPlus' POV he is discharging the battery because he is pulling energy from there.
That's totally normal.
If the MultiPlus is pushing energy to the battery it shows charging.
Power is coming from solar, net energy change is power going to the battery albeit from solar not from the inverter. So the battery is not discharging in any form. If the inverter is neither charging nor discharging the battery, the correct status used in VRM is idle. That is a confusing and contradictory way of showing state, as it is specifically referring to battery use.
It used to show in the MFD app as a second battery. That's been removed now with the new MFD version.
Looks perfectly normal, here is mine
It doesnt refresh fast, so values are a bit off at time
Its the DC bus measurement so Battery and or PV
BMS and BMV in addition to Quattro:
It has always been this way. This display is activated by choosing to display the inverter battery monitor's state. The inverter battery monitor can't see any incoming current from other sources - it only sees outgoing unless the inverter itself is charging. It is drawing from the DC bus (even if solar is providing a surplus of charge), so it's discharging.
43 People are following this question.
