Hi all
Does anyone know if either the 712 or the mppt 100/30 have the capability of starting a generator on an alarm activation?
Thanks
Mickc
Hi all
Thanks
Mickc
Easyiest way is with BMV. Maxiumratings of that BMV realy are 60V / 1A
You also can do it with SmartSolar and a Digital TX Cabel combined with a SolidStateRelay
Here is the official doc:
https://www.victronenergy.com/live/auto-generator-start-stop:start
Fantastic, I have s three point Onan genset and your attachment is spot I. For that...well done, kudos!!
3 People are following this question.
Are 50vdc solar panels wasted on a 12vdc system?
SmartSolar MPPT 150/85 VE.Can - No current flow in Bulk with PV at VOC
Peak Power Pack 40Ah and SmartSolar charge controller - how to connect & setup
Large difference between solar blanket voltage output and Victron dashboard
Why MPPT sizing system is recommending 150/35 and not 100/50 ?
