Timo Engelmann avatar image
Timo Engelmann asked
More than one Orion XS 12/12-50A DC-DC parallel - how much VE.direct connections?
We are planning to use 3 or 4 Orion XS 12/12-50A DC-DC in parallel to supply our system with up to 2.1 kW. Is it possible to use only one VE.direct port to get the sum of all DC/DC values and e.g. control the current limiting?
Maybe it is possible to set up a VE.smart network between the DC/DCs and the master DC/DC transmits the data from/to the VE.direct port.
Otherwise we would need 3 or 4 separate VE.direct lines, which would be a great pity.
VE.Directorion xs
VE.direct is a direct connection from one device to a GX device.
You need one cable for each device.
Timo Engelmann avatar image Timo Engelmann commented ·
Hi Matthias,
thanks for the fast response!
Unfortunately, it's not my dream answer. But it is what it is.
Best wishes,
Timo
