maidstein avatar image
maidstein asked
Orion XS starts new cycles when engine shutdown has been detected
The Orion XS always starts new cycles once an engine shutdown on input has been detected, even though the battery voltage on output has not dropped below the re-bulk voltage.
I have connected an alternator and a solar charge controller (SmartSolar MPPT 100|50) and a battery to the input of the Orion XS. If the voltage at the input of the Orion XS drops below the shutdown voltage of the engine shutdown detection for at least 60 seconds, the Orion XS stops charging at that point at the latest. That is correct.
If there is enough voltage at the input of the Orion XS, a new charging cycle is started, even though the battery voltage at the output of the Orion XS has not dropped below the float voltage, the storage voltage or the re-bulk voltage (offset). This means that charging is always carried out up to the absorption voltage once an engine shutdown has been detected.
This is a fatal error and must be urgently corrected in the next firmware update!
Thank you!
orion xs
pwfarnell avatar image pwfarnell commented ·
Everything like a solar controller, alternator controller, inverter etc. starts a new cycle when turned on unless you have managed battery control through a Cerbo. The thing is to make sure that the settings are input correctly so that it rapidly goes from absorption to float. Setting something like a fixed 3 hr absorption period when you are in a van or RV that might be turned off many times a day would be a poor choice of settings. Victron adaptive absorption will reduce the absorption time if the battery voltage is high. Tail current setting will end absorption very quickly with full batteries but can be fooled by loads unless you have the device linked to a shunt/ battery monitor.
3 Likes 3 ·
It's normal behaviour. Why do you see it as a fatal error?
2 Likes 2 ·
maidstein answered ·
Hi @kevgermany and @pwfarnell! Thank you for your replies!
I'm sorry, I don't think this is normal behavior. So I stick to my verdict of "fatal error".
But before I go too deep into this, I have to say that I was hasty with my error diagnosis and that I need to correct it.
The strange charging behavior (that the Orion XS seems to spontaneously start new charging cycles) also seems to be independent of the engine shutdown detection. Yesterday I had a voltage on the input side of the Orion XS above the threshold of the engine shutdown detection voltage for a whole day. Despite this, for some unknown reason, it was charged about 6 times yesterday with the absorption voltage (14.4 V). Because there was currently no load connected to the battery (LiFePO4) at the output of the Orion XS, the voltage never dropped below 14.25 V. The float voltage is set to 13.35 V and the storage voltage is set to 13.25 V.
Why does the Orion XS keep spontaneously charging with absorption voltage (14.4 V)?
The Orion XS may not even charge until it reaches the float voltage and later the storage voltage. Do you agree?
Without knowing details, just throwing out some ideas which I would not expect to see
Transient loads on the starter battery
Alternator delivery voltage transients
Loose or bad wiring connection, isolator, fuse etc. between the starter battery and the Orion.
A faulty Orion
Recheck all wiring and components in the supply.
Try the Orion activation by a different method such as wiring to the remote terminal rather than starter voltage detection to see how it works.
2 Likes 2 ·
maidstein avatar image maidstein pwfarnell commented ·
Thank you for your ideas for narrowing down the problem!
First, let me show you my circuit.
I monitor the starter battery using a Smart Battery Sense. The historical data from the Smart Battery Sense shows absolutely no drop in voltage for more than 60 seconds, which is why the Orion XS's engine shutdown detection probably did not trigger.
But even if the voltage had been below the engine shutdown detection voltage and later above the start voltage or delayed start voltage, the Orion XS would not have been allowed to charge again because the voltage on the additional battery was still well above the storage voltage and float voltage.
I think it's a good idea to deactivate the engine shutdown detection as a test to see whether the Orion XS still starts unexpected and unwanted new charging cycles from time to time.
Incidentally, the unexpected and unwanted new charging cycles are also not displayed in the history tab of the Victron app (Victron Connect). This obviously only happens in the background. In addition, the time data in the history tab for each of the 5 charging phases is not at all plausible. It all looks like very unfinished software to me.
It would be nice if an official representative from Victron Energy could comment on this.
Thank you very much!
pwfarnell avatar image pwfarnell maidstein commented ·
@maidstein The only comment I have is the solar connection to the start battery, I know it keeps the start battery full even with loads on the battery, but it is usual for the solar to be on the leisure battery and if needed add a trickle charge to keep the starter battery full. The solar may be causing voltage fluctuations which are misinterpreted as engine stops and starts, again just trying to suggest ideas as to why you are having an unusual problem and what you are doing different. I have no personal experience of the Smart Battery Sense and how good its logic is.
2 Likes 2 ·
The fact that the solar charger causes small voltage fluctuations on input of Orion XS can hardly be the problem, because the engine shutdown detection only reacts when the voltage is getting below the shutdown voltage for at least 60 seconds. There have definitely not been voltage drops that long and that deep. The Smart Battery Sense produces very accurate historical datas like the BMVs and SmartShunts do.
But even if there were. The Orion XS should not charge even after falling below the shutdown voltage and then exceeding the (delayed) start voltage, as long as the voltage of the leisure battery is above the float voltage (and storage voltage).
The fact that the solar charger is connected to the starter battery has the advantage that the leisure battery can be charged via alternator and solar charger with the help of Orion XS.
