4711austria avatar image
4711austria asked
LifePO4 Gobel PC200 16S 280Ah Standard, cell 9 always higher or running lower?
would like to get the point, what is the cause for that behavior.
Cell 9 (no fuse, all busbars on 5Nm, nothing to see inside the pack) is a runner
1) low voltage, always running behind
2) getting charges, starts running higher as all other cells
3) on getting full, voltage is getting lower, running down (only the balancer stops that)
Normaly the balancer kicks in on 3,45V, that is not the daily voltage (3,375-3,4).
1) morning, the power is needed, cell voltage is the lowest
2) during charging, the voltage is higher
3) on getting full, the volatge starts running down (until the balancer kicks in)
- is it a cell with higher/lower cap?
- faulty cell?
- normal behavior on other gupe?
Thx!
lifepo
Alexandra avatar image
Alexandra answered ·
@4711Austria
This is battery related question not a Victron question, but anyway.
Internal resistance both in the cells (and connections to and from) and bms balancing (triggering and tolerance) is the answer.
Then there is ohms law. So in charge outer cells rise faster and drop faster in discharge.
You could always rebuild the pack (rearrange cells) and see if you can change the behaviour.
If it is always one cell in particular then it just has different ESR. Could be faulty could just be different. Cant tell over the internet.
4711austria answered ·
thx for answer, what is ESR?
I measured all resistances on the busbar (cannot reach the pole), they are all the same
arranging would be test, but means complete demount of the pack.
what I really want to figure out is, is it of concern or just a behavior I can ignore during the cell diff voltage does not rise more ?
Alex Pescaru avatar image Alex Pescaru commented ·
It's a term specific to capacitors - equivalent series resistance, but can be used when describing the internal resistance of the battery.
See https://en.wikipedia.org/wiki/Internal_resistance
4711austria avatar image 4711austria Alex Pescaru commented ·
cells should be matched from Gobel in this pack, just one is running
