Bluesmart is in Lion Mode. Battery reached 100% with 13.36V at the moment.
87.57Ah charged so far. not changing any more but the bluesmart keeps going on with 4Amps in Bulk mode.
Should I keep it plugged to the battery? how long?
Ensure that the absorption voltage is 50 - 100mV below the battery manufacturer's maximum.
@d0minik your Liontron battery wont be fully charged until it gets to 14.2v or so.
You can use the lithium preset in the BlueSmart 12-4 charger. It just needs more time to finish charging, esp if you have any loads connected.
41 People are following this question.
