mopanie avatar image
mopanie asked
Power from PV inverter connected to Multiplus AC IN not used
Hi
I would like to have some thoughts on this issue:
I have the following setup:
Multiplus with Generic PV inverter connected to the AC IN of 2 x 3kVa Multi and SMA SunnyBoy Connected to the AC OUT of the Multis. The Generic PV inverter connected to the AC IN is being monitored by the victron current sensor: https://www.victronenergy.com/meters-and-sensors/ac-current-sensor
For some reason, victron is not using the power generated by the generic PV inverter connected to the AC IN of the Multi, this power is just being feed into the grid:
And it seems like the Generic PV inverter is setup correctly:
AC PV Coupling
Alexandra avatar image
Alexandra answered ·
@Mopanie
It is more like it is not being considered at all.
If I just do basic maths on the tiles screen....
(3,058+661)-(1,597+1,475)=647 remove 70w for system consumption - 577 to grid.
How is it connected to the system?
How is it configured on the GX?
I haven't used one personally but does it have a CT direction as well?
