m-d avatar image
m-d asked
CerboGX unusable after v3.30, revert also fails
Since updating the firmware to v3.30, I am unable to receive any status on my DC system, battery SOC, and PV array inputs. The update itself was labeled as “successful”, but nothing works. I rolled back to v3.13 (the prior version I had installed), but the same result occurs minus the little triangle with the “!” in it on the display.
The wiring has not changed. I have rebooted the system multiple times to attempt a refresh, but am no longer able to take any action with a positive result. I do not have VRM set up.
cerbo gx
