julianbridgewater avatar image
julianbridgewater asked
EASYSOLAR 1600/12 toriod humming.
Hi there,- have a stand alone off grid EasySolar 1600/12.
It has PV and batterys,- they charge fine and are full.
There is NO connection to the mains grid.
There is a buzz / hum from the inverter [torodial transformer] which was not there when new.
The inverter works fine and produces power,- very nicely.
This hum is there even when the mains power output connector is unplugged from the bottom of the inverter [so not even wiring or socket connected!]
the hum is NOT the cooling fan,---this is stationary normally but does kick in under load.
The inverter did not make this noise when first fitted.
I would appreciate any advice but I feel that this unit should be returned to victron
Regards JULIAN.
EasySolar All-in-One
Jaco Reinecke avatar image
Jaco Reinecke answered ·
Not sure if my humming is your buzzing?
I have a Multigrid inverter. I hear a humming when it is inverting from batteries, which is perfectly normal.
Hopes this gives you an idea.
Regards
Jaco
ejrossouw avatar image
ejrossouw answered ·
@julianbridgewater My MP IIs always humms ever so slightly even when not inverting and it becomes more noticeable under higher inverter load. Mine is a home installation and I'd always suggest to mount it out of "sight".
