georgerobaina avatar image
georgerobaina asked
MultiPlus Trickle Cahrging for Starter Battery
Hello and Greeting from Australia:
I have Lithium House Batteries (24volt)
I have Normal Lead Acid Starter Batteries (24Volt)
My Question is
1. Is the Trickle Charger a smart charger for example does it offer Bulk Absorbition and Float Charge ( my main question is can or do i just leave it connected all the time)
2. Can I choose the charge parameters for the trickle charger only or does the trickle charger only use the main charge characteristics
Thank You
Temperature Sensor
Mark avatar image
Mark answered ·
The 2nd 4A charge output is just a constant voltage output trickle charger.
The voltage should be somewhere around typical float voltage, maybe a bit lower. Best to just get a multimeter out and measure it for yourself.
No it can't be configured and only charges batteries of the same nominal voltage as the MultiPlus supply.
Victron temperature sensor disambiguation table - which product supports which sensor
