campervantime avatar image
campervantime asked
Config of Battery Aggregator
Hi Everyone
Have setup Battery Aggregator today as I have 2 installed smartshunt IP65 monitoring 2 different AGM batteries that are connected in parallel. One is 70ah and the other is 92ah, but when I check on the 'capacity' section of battery aggregator it says zero ah. I have had a look at the GitHub page for aggregator (https://github.com/pulquero/BatteryAggregator) and it says I can set it. I am new to editing files on the cerbo but have enabled SSH login etc.
Can anyone point me in the right direction, and is setting the capacity in Aggregator really needed as doesn't it just pull the two shunt data together and average/merge?
Thanks
SmartShunt
matt1309 avatar image matt1309 commented ·
Hi @campervantime
I can't help regarding the specific driver but editing files over ssh i prefer to use the text editor nano.
I cant remember if it's installed by default. if not you can install using
opkg install nano
Recommend having a quick google of how to use nano to edit files on linux and then you should be able to edit files in command line (ssh).
