Paul LaRocque avatar image
Paul LaRocque asked
500A Smartshunt. The bolts appear t be M10x1.5 and made of brass. If I need a slightly longer bolt do I need to use only brass, or is other metal acceptable?e?
SmartShunt
Mike Dorsett avatar image
Mike Dorsett answered ·
This depends on the corrosive level of your environment. You can use stainless steel bolts with no problems. Passivated mild steel bolts should be avoided in damp or salty conditions.
jwfrary avatar image
jwfrary answered ·
Probobly better to utillise a buss bar rather than jamming loads of kit on the one bolt.
