Ari Kesti avatar image
Ari Kesti asked
MPPT limited when no grid. Video showing problem.
Hi Community
Upgraded my Quattros firmware to latest and now i have to have grid on to allow MPTTs to use full potential of the sun.
When i turn off the grid the MPTTs are throttled back significantly. I did the upgrade of the Quattros but i am unsure if i got all my settings back to where they where before. The conversion of the settings file didn’t work ☹️. Can someone guide me to where in the settings i can have a look?
Video showing the nature of my problem:
https://youtu.be/ZLOl2_lbPKE?si=i6IaNv1LjN4dNrIJ
Last sequence shows my components and software versions.
The batteries have Rec BMS.
MPPT ControllersMultiPlus Quattro Inverter Chargergrid
Alexandra avatar image
Alexandra answered ·
@Ari Kesti
Did you upgrade everything Victron in the system?
If not start there.
Ari Kesti answered ·
Hi Alexandra
I updated everyting to latest. MPTTs are on beta software.
But my problem came with the v510 firmware on my Quattros. Or i messed up some settings when re-configuring the settings in the inverters. The settings conversion tool didn’t work..
It is a strange behavior. Grid on = full power on the mppts and when i turn off grid they only produce for direct consumption. Like it doesn’t want to allow charging without grid present.
I am scratching my head on this.
Start here. Pull the current configuration remotely, check it and fix anything that is wrong, check any assistants and apply the configuration again.
mondeoman avatar image
mondeoman answered ·
"Rec BMS" - I assume it has CAN communication to the GX Device.
Can you take a look at the Charge / Discharge current limits (CCL, DCL) in the battery menu of the GX Device when On Grid / Off Grid?
