bulmonoss avatar image
bulmonoss asked
EV Charging Station contactor lifespan
I want to share mi worries about the contactor of the EVCS, this is what happended:
I had my car charging in manual mode, it finished charging, everything as expected, 40 minutes later I went to the garage to take the car and I found the EVCS with the screen totally corrupted and the contactor switching +/- every 5 seconds:
I turned off the supply to the charger and reboot it a few hours later, everything worked fine until the screen turned like this:
After that I rebooted it again, and it's been working fine for more than a week.
Has anyone experienced something like this? And about the contactor, it’s definitely not thought to switch every 5 seconds, any idea of how many times can it switch in its lifespan?
Thanks.
ev charging station
Are you running the latest FW?
bulmonoss avatar image bulmonoss Lucian Popescu (Victron Energy Staff) ♦♦ commented ·
Not the 28 yet, the V01.27.
Please check your email
bulmonoss answered ·
Hi, the problem has been solved thanks to @Lucian Popescu (Victron Energy Staff).
The wires powering the contactors’ coil have been rerouted to avoid passing too close to the communication cables between screen and the main PCB.
Also a ferrite core has been put around the communication cables.
Thanks for doing that yourself!
