If no technical reason not to I would prefer to connect to the Cerbo
If you need it for temperature compensated charging or low temp cut off then connect it to the Multiplus.
If you just want stats then use the Cerbo or to trigger a fan or something
So the answer is it depends on what you need it for
I understood the system was clever and could uses one battery temp sensor to instruct the Multiplus and other items Throug its network?
In the GX devices which control the systems is a setting called Shared Temperature Sense or STS. This needs to be turned on.
You'll find it under settings/DVCC
Victron temperature sensor disambiguation table - which product supports which sensor
43 People are following this question.
