pekkaj avatar image
pekkaj asked
Max good temperature for Multiplus-II
Just got Mk3 so I'm able to experiment with different charge powers and monitor the temp. At max charge power Multiplus overheats occasionaly. What would be a good target temperature when charging for Multiplus? 40 Celcius?
Multiplus-IItemperature
ejrossouw avatar image
ejrossouw answered ·
@pekkaj Ambient temperature at 25 degrees C should be your reference target and even lower as the internal device temperature will obviously be much higher under load. If you look at the spec sheet it shows the derating when inverting as a guide. Personally I charge at 60-80% power when for prolonged periods e.g. 4 hrs. Also, ensure there is adequate airflow for the device.
MultiPlus-II Product page
MultiPlus-II Manual
MultiPlus-II 230V Datasheet
VE.Bus Error codes
