Matt drummond bell avatar image
Matt drummond bell asked
Installing serial dbs
Hi once again another question that probably no one will answer…..
serial dbs , does it have to be installed with batteries connected? I have a standalone system and everything except for rpi and usb bus are power connected. So I have to install drivers whilst I have power and internet. However the ccl and voltage limits aren’t being loaded from the bms to the system. Could this be because of pre installation ? Daly bms
Other than this all works fine with 6 bms s and batt aggregator
Thanks
offgrid
