roblatour avatar image
roblatour asked
Adding an icon to the Remote Console on LAN
I'm running Venus on a RPi and noticed that Remote Console on LAN (i.e. the browser window you get when you bring up venus.local in your web browser) does not have default icon.
As a result when you view that page, or if you have a shortcut in your favourites list, you will see a broken icon link) rather than a more helpful identifying icon.
Here is what I did to resolve:
Step 1:
Created my own icon; for this I used https://www.favicon.cc/ and download it; it is a little picture of the sun. The file is called favicon.ico and is included in the attached .zip file if you want to use it.
favicon.zip
Alternatively, you can use Victron's icon; you can download it from here:
https://www.victronenergy.com/static/favicon.ico
Step 2:
SFTP into venus.local using FileZilla ( https://filezilla-project.org/ ).
For this I used the user id: root and my password.
Step 3:
Navigated to the directory
/var/www/venus
and created a new directory under it called
images
Step 4:
Copied the file favicon.ico (created in Step 1 above) into the folder /var/www/venus/images
Step 5:
Download the file
/var/www/venus/index.php
Step 6:
edited the index.php file index.php to contain the line:
<link rel="icon" type="image/x-icon" href="images/favicon.ico">
directly under the existing line:
<title>Remote Console on LAN</title>
and saved the change.
Step 7:
uploaded the file index.php into /var/www/venus/ replacing the existing index.php file
That's it - here are the results:
(I've added an issue on Github for this: https://github.com/victronenergy/venus/issues/1250 )
Venus OS
favicon.zip (292 B)
